I am getting error "Unable to locate method 'public void Authentication'" while using 'DataScope REST API Examples' C# .NET.
How can i solve this issue.
Hi @denis.gomes,
I downloaded the latest Refinitiv DSS C# example application from here and was able to build it and run without issues. Can you try doing the same. Note: that there is already a prebuilt binary in the Release directory which you can try to run as well.
Hi @denis.gomes,
Are you referring to the DSS C# sample application available here?
Can you post the screenshot of the error message?
