C# DSS : An error occurred while sending the request
I have downloaded the ".Net SDK Tutorial 1: Connection to the DSS server" from
https://developers.refinitiv.com/en/api-catalog/datascope-select/datascope-select-rest-api/tutorials#net-sdk-tutorial-1-connecting-to-the-dss-server
When I run restful_api_core_gui_starter.exe, the program interrupts at
string sessionToken = extractionsContext.SessionToken;
and MSVS 2013 shows an exception
I have a DSS account with it I can login to DSS https://hosted.datascope.reuters.com/DataScope/
without any problem.
Does anyone can give me a hint, why it happens ?
Thanks in advance.
Tru
dss-rest-apidatascope-selectdssc#
@THUANTRU.HANG
Have you used DSS .NET SDK version 11.3?
You can download it from here.
The code looks like:
ExtractionsContext extractionsContext =
                 new ExtractionsContext(dssUri, dssUserName, dssUserPassword);
WebProxy proxy = new WebProxy("http://proxy:port/", true);
proxy.Credentials = new NetworkCredential("proxyuser", "proxypassword");
extractionsContext.Options.Proxy = proxy;
extractionsContext.Options.UseProxy = true;
Hi Jirapongse,
thank for your hints.
After adding proxy credential it works fine.
Regards,
Tru
Hi, @THUANTRU.HANG
Please inspect the detail exception message and post it here. The message should contain the reason why the exception was invoked.
Hi Steven,
it seems a problem with the proxy authentication.
The InnerException message shows:
"The remote server returned an error: (407) Proxy Authentication Required."
But how can I fix it ?
I can't find any hint in the documentation.
Thanks for your help
Tru
