How to retrieve the full set of FID details available in TickHistoryRaw using the .NET API?
Hi all,
I would like to know whether it is possible to access the list of FIDs with all the details available in TickHistoryRaw reports (shown below) via the .NET API.
More specifically, I would like to find a FID number by FID name. For example, if my input string is "GV1_DATE", I would like to get the corresponding FID number, which in this case would be 1028. Is this something that can be done in C#?
Thank you and kind regards
dss-rest-apidatascope-selectdsstick-history-rest-apic#.net
23k 22 9 14
Hello @Vlad,
Check out GetHistoricalFidDefinitions() method in ExtractionsContext.
The naked request that can be tried in Postman tool:
                {protocol}}{
                {host}}{
                {api}}Extractions/GetHistoricalFidDefinitions
It returns the map, un-ordered:
            "Code": "1",
            "Name": "[PROD_PERM] PERMISSION"
            "Code": "2",
            "Name": "[RDNDISPLAY] DISPLAYTEMPLATE"
Hi, that is exactly what I needed - thank you very much!
