WebSocket API - Login Rejected. Watchlist size of 25000 for 'WS JSON2' connection ...
Hi Team,
I am using WebSockets, C# 'MarketPriceRdpGwAuthenticationExample' app and facing the following issue.
"Text": "Login Rejected. Watchlist size of 25000 for 'WS JSON2' connection is outside of range [3001,20000] supported for this ADS fanout tier for this type of connection."
Could you please let me know what is the meaning of this message and how it can be resolved.
websocketsc#
9.7k 49 38 60
Hi @denis.gomes
The issue may be related to the specific endpoint tier you are connected into. Based on the response, your account setup would not allow you to properly manage a watchlist based on your watchlist license.
Refer to this question: https://community.developers.refinitiv.com/questions/75384/login-rejected-watchlist-size-is-outside-of-range.html
