WebSockets client in C#: which library?
You are using the third party WebSocketSharp library in your examples. Is there any reason why to avoid the "System.Net.WebSockets" library - part of .NET framework?
websocketsrrtoc#.netrefinitiv-realtime-optimised
9.7k 49 38 60
Hi @stanislav_slavik,
You should be able to use any WebSocket implementation, including System.Net.Websockets. In fact,this .Net example is using it: https://github.com/Refinitiv/websocket-api/tree/master/Applications/Examples/RDP/CSharp
