Hi
I am using Csharp MarketPriceExample of EAP (Early Aceess Program) -> TR's Simplified Streaming API. I am aware that we can enable data compression in Simplified API .(i.e. permessage-deflate compression ) . I have a question regarding how we can request compressed data in CSharp MarketPriceExample ?
Look Like CSharp example is using open source websocketsharp dll. I had a look into websocket-sharp dll document for compression here -> https://github.com/sta/websocket-sharp#per-message-compression
i.e.
"As a WebSocket client, if you would like to enable this extension, you should set the WebSocket.Compression property to a compression method before calling the connect method. ws.Compression = CompressionMethod.Deflate;
And then the client will send the following header in the handshake request to the server. Sec-WebSocket-Extensions: permessage-deflate; server_no_context_takeover; client_no_context_takeover "
Anyhow i am not able to set the header while requesting data from simplified streaming ?
Could you please suggest how we can add that compression request part in MarketPriceExample code for Simplified Streaming ?
