I need to compile EMA 2.0.3.L2 on Windows because we use an extra "Debug" build with _ITERATOR_DEBUG_LEVEL=1 , which is not compatible with the Debug build that Refinitiv provides. Before making any changes to the build process to make this new Debug library, I tried to build the existing libraries. I followed the instructions in Section 5 CMake of the RTSDK_C_Installation_Guide.pdf, running the following command to generate the VS solution and project files:
cmake -H. -Bbuild -G "Visual Studio 16 2019" -A x64 -DBUILD_UNIT_TESTS=OFF -DBUILD_EMA_DOXYGEN=OFF -DBUILD_EMA_EXAMPLES=OFF -DBUILD_EMA_PERFTOOLS=OFF -DBUILD_EMA_TRAINING=OFF -DBUILD_EMA_UNIT_TESTS=OFF -DBUILD_ETA_APPLICATIONS=OFF -DBUILD_ETA_DOXYGEN=OFF -DBUILD_ETA_EXAMPLES=OFF -DBUILD_ETA_PERFTOOLS=OFF -DBUILD_ETA_TRAINING=OFF -DBUILD_ETA_UNIT_TESTS=OFF -DBUILD_32_BIT_ETA=OFF -DBUILD_RTSDK-BINARYPACK=OFF
I opened the rtsdk.sln file in the "build" directory that the above command created, and built the solution (selecting the Build / Build Solution menu option). I expected the library files to be built, but none were.
The following text was shown in the output:
1>------ Build started: Project: ZERO_CHECK, Configuration: Release_MD x64 ------ 1>Checking Build System 2>------ Skipped Build: Project: ALL_BUILD, Configuration: Release_MD x64 ------ 2>Project not selected to build for this solution configuration ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 1 skipped ==========
Any ideas why no build was done? This is the first time I have built Refinitiv libraries, so I'm probably making a basic mistake.
