Hello Team,
Is there a way to build ESDK(JAVA) environment without using Gradle?
The tutorial above explains the build using Gradle and Gradle requires access to Internet during the ESDK build process. However we are running ESDK(Java) on a machine without internet connectivity so please advise alternate method to build ESDK(Java) environment.
Thank you.
Regards
