Compiling EMA 1.3.0L1 Windows
I'm having problems compiling EMA 1.3.0L1 for Windows on VS2017
I have followed the guide at
https://developers.refinitiv.com/elektron/elektron-sdk-cc/learning?content=43559&type=learning_material_item
But I noticed that a lot for the paths in include directories does not exists in 1.3.0L1. Eg there is several include path to <EMA Root>\Cpp-C\Eta\Utils\... but looking the the files there is no path called that.
Is there an updated guide for this version?
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apivisual-studio
Hi @jens
Thanks for pointing out the discrepancy - I will alert the content owner to have it amended.
Please refer to the ESDK_C_Installation_Guide - which can also be found in theCpp-C\Eta\Docs or Cpp-C\Ema\Docs folder of ESDK v 1.3.0
This document details the difference in the build process, directory structure etc. between versions prior to v1.2 and v1.2 onwards.
