Tick History (DS) REST API - Original Input Identifier Not Included in Output Response?
I'm interested in advising client to use the Bulk Historical Search to get RICs from a list of identifiers , in this case resolving from using ISIN (input) to RIC (output).
The below appears to be what I am looking for, however the result do not include the original identifier being used so I am unable to determine which ISIN each RIC in the was resolved from:
POST https://selectapi.datascope.refinitiv.com/restapi/v1/Search/HistoricalBulkSearch
Authorization: Token {
                 {Token}}
Prefer: respond-async
Content-Type: application/json; odata=minimalmetadata
    "Request": {
        "Identifiers": [
                "Identifier": "CND1000291L3",
                "IdentifierType": "Isin"
                "Identifier": "CND1000014N5",
        "Range": {
            "Start": "1996-01-01T00:00:00.000Z",
            "End": "2021-09-17T00:00:00.000Z"
Example truncated output, I was expecting the original identifier to form part of the collection:
    "@odata.context": "https://selectapi.datascope.refinitiv.com/restapi/v1/$metadata#DataScope.Select.Api.Search.HistoricalBulkSearchResult",
    "Results": [
            "Identifier": "190006=CCTB",
            "IdentifierType": "Ric",
            "Source": "",
            "Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHwxOTAwMDY9Q0NUQnw",
            "Description": "Historical Instrument",
            "InstrumentType": "Unknown",
            "Status": "Valid",
            "DomainCode": "6",
            "FirstDate": "2020-04-30T00:00:00.000Z",
            "LastDate": "2021-09-11T00:00:00.000Z",
            "History": []
            "Identifier": "190006=CCTZ",
            "Source": "",
            "Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHwxOTAwMDY9Q0NUWnw",
            "Status": "Valid",
            "DomainCode": "6",
            "FirstDate": "2021-05-27T00:00:00.000Z",
            "History": []
            "Identifier": "CN019616=ESS",
            "Source": "",
            "Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHxDTjAxOTYxNj1FU1N8",
            "Status": "Valid",
            "DomainCode": "6",
            "FirstDate": "2019-06-03T00:00:00.000Z",
            "LastDate": "2021-09-17T00:00:00.000Z",
            "History": []
Is the original identifier something that could be added to the response collection?
Best regards,
Gareth
tick-history-rest-api
23k 22 9 14
Hello @gteage ,
Depending on the use case requirements, and if RDP permissioining is available, you may wish to proceed via RDP Search Beta, a very simple usage, for example:
https://{
                {RDP_HOST}}/discovery/search/v1/
    "View": "Instruments",
    "Filter": "ISIN in ( 'CND1000291L3' 'CND1000014N5')",
    "Select": "ISIN, RIC"
Resulting in:
    "Total": 2,
    "Hits": [
            "ISIN": "CND1000291L3",
            "RIC": "CN190006="
            "ISIN": "CND1000014N5",
            "RIC": "CN080020="
Or RDP Symbology, for example:
https://{
                {RDP_HOST}}/discovery/symbology/{
                {RDP_VERSION_SYMBOLOGY}}/lookup
    "from": [
            "identifierTypes": ["Isin"],
            "values": ["CND1000291L3","CND1000014N5"]
    "type": "auto",
    "to": [
            "identifierTypes": ["RIC"]
Resulting in:
    "data": [
            "input": [
                    "value": "CND1000014N5",
                    "identifierType": "Isin"
            "output": [
                    "value": "CN080020=CFIC",
                    "identifierType": "RIC"
                    "value": "CN080020=CNMB",
                    "value": "CN100820=SZ1",
                    "value": "CN080020=SYSJ",
                    "value": "CN080020=RRPS",
            "input": [
                    "value": "CND1000291L3",
            "output": [
                    "value": "CN190006=SYSJ",
                    "value": "CN190006=RRPS",
                    "value": "CN190006=IBCN",
@zoya.farberov Thanks Zoya, I think the RDP Symbology API option works well as it appears to be syncronous only.
Many thanks,
Gareth
23k 22 9 14
Hello @gteage ,
Would it work for your use case to proceed this way:
    "Request": {
        "Identifiers": [
                "IdentifierType": "Isin",
                "UserDefinedIdentifier": "CND1000291L3"
                "UserDefinedIdentifier": "CND1000014N5"
        "Range": {
Resulting in:
    "@odata.context": "https://selectapi.datascope.refinitiv.com/RestApi/v1/$metadata#DataScope.Select.Api.Search.HistoricalBulkSearchResult",
    "Results": [
            "UserDefinedIdentifier": "CND1000291L3",
            "Source": "",
            "Status": "Valid",
            "DomainCode": "6",
            "History": []
