We are using the pull option to retrieve data (tickhistory.thomsonreuters.com/HttpPull/List ?dir/api-results ) and would like to know if we can purge the folder api-results ?
There is currently no API call to do a bulk deletion on generated result files on the API results folder. The API "CancelRequest" call however, can perform a deletion, but you are required to have the friendly name of the request to be deleted.
Another option is to ask the TR TRTH development team do the cleaning up of API results folder. This can take 2-4 days.
