Connect to AWS Ohio for Refinitiv Real-Time – Optimized (RTO) using the Real-Time Legacy Protocol Converter (LPC)?
How can I connect to AWS Ohio for Refinitiv Real-Time – Optimized using the Real-Time Legacy Protocol Converter?
elektronrefinitiv-realtimeelektron-sdkrrtlpc
Hi @Mike.Karl
You can connect to a specific region by specifying the region in the Real-Time Legacy Protocol Converter configuration file. To connect to Ohio configure the following lpc.cnf parameter as
 *lpc*serviceDiscoveryLocation : us-east-2
and you will be able to set your Service Discovery to target AWS Ohio.
Please note that at this time Real-time – Optimized Ohio connectivity has only been tested with Real-Time Legacy Protocol Converter v1.2.
