Error file User_List.txt
I have an error:
This error is relative an execute script ./lpcSetup.sh
Installation Warning: user_list.txt file is not found or is empty. Please be sure to create a user mapping file for lpc use. Consult the installatio
elektronrefinitiv-realtimeelektron-sdkrrterrorlpc
@R.Costa
I got the same warning if I didn't add any users while configuring the LPC.
We will now configure the mapping file containing the list of users or apps to connect to LPC.
Install will now prompt for User Name (used by applications), Machine ID, and Machine ID Password
Contents of current user_list.txt file
(a)dd, (d)elete, (m)odify, (q)uit: q
Installation Warning: user_list.txt file is not found or is empty.  Please be sure to create a user mapping file for lpc use.  Consult the installation manual for more information.
You need to add at least one user while configuring the LPC to avoid that warning.
(a)dd, (d)elete, (m)odify, (q)uit: a
Application User Name : developers
Machine ID Account: test
Machine ID Password: test
user developers added.
You can refer to the Installing Legacy Protocol Converter 1.2 On VirtualBox video regarding the LPC installation.
Hello @R.Costa ,
If you wish to edit user_list.txt as suggested by @jirapongse.phuriphanvichai , you have the option to do so using script userListSetup.sh included with the installation of LPC.
In Installation Guide document, find section F.1 Shell Script User Password Management Utility describing how to use the script.
