RTSDK CMake Error: download binarypack fail
Hi, I'm building RTSDK with cmake. An error occur when I run "cmake -H RTSDK -B RTSDK_binary" as follows:
It seems like a connection error, but I did successfully download the whole project pakcage from github with git clone. How can I fix the problem? Could you please help me out?
I'm working on centos 7. Thanks!
elektronrefinitiv-realtimeelektron-sdkrrt
@Fei
Thank you so much for the update.
In this case, it could be a problem in the cmake, as mentioned in this thread.
It works fine for me when using the cmake downloaded from https://cmake.org/files/v3.11/cmake-3.11.2-Linux-x86_64.tar.gz.
You may use a workaround by using curl to download the required packages and then copying the packages to the destination folders. For example, copy RTSDK-BinaryPack-2.0.1.L1.tar.xz to the /home/renfei/RTSDK_build/external/dlcache/ directory.
Hello @Fei
You can also download the RSDK C++ package from the Developer Portal download page. The downloaded package will already contain the RTSDK-BinaryPack files and folder.
@Fei
It could be a problem in curl or libcurl library, as mentioned in this thread. You can use the following command to verify their versions.
rpm -q curl libcurl
The output looks like this:
[root@f679e006d4b0 /]# rpm -q curl libcurl
curl-7.29.0-59.el7.x86_64
libcurl-7.29.0-59.el7.x86_64
You can also use the following command to try the HTTPS connection with curl.
curl -L https://github.com/Refinitiv/Real-Time-SDK/releases/download/Real-Time-SDK-2.0.1.L1/RTSDK-BinaryPack-2.0.1.L1.tar.xz -o RTSDK-BinaryPack-2.0.1.L1.tar.xz
Thanks. I checked my curl version, it's like
" [root@878a1235d479 renfei]# rpm -q curl libcurl
curl-7.76.1-2.0.cf.rhel7.x86_64
libcurl-7.76.1-2.0.cf.rhel7.x86_64 "
and download goes ok with curl:
But cmake still fails.
