I am getting below error in pythong when using RTH REST Api:
Quota Message: INFO: Tick History Futures Quota Count Before Extraction: 0; Instruments Approved for Extraction: 0; Tick History Futures Quota Count After Extraction: 0, 100% of Limit; Tick History Futures Quota Limit: 0 Quota Message: ERROR: The RIC 'STXE' in the request would exceed your quota limits. Adjust your input list to continue. Quota Message: WARNING: Tick History Futures Quota has been reached or exceeded
I have checked from the GUI and it says below:
What should i do in this case ? Do i need to change anything in Python code or need to contact ny Refinitiv Account manager ?
Below is my Python Code:
# coding: utf-8 # In[2]: # ==================================================================================== # On Demand request demo code, using the following steps: # - Authentication token request # - On Demand extraction request # - Extraction status polling request # Extraction notes retrieval # - Data retrieval and save to disk (the data file is gzipped) # Includes AWS download capability # ==================================================================================== # Set these parameters before running the code: filePath = "P:\\ODI_Projects\\temp\\" # Location to save downloaded files fileNameRoot = "Python_Test" # Root of the name for the downloaded files useAws = True # Set the last parameter above to: # False to download from TRTH servers # True to download from Amazon Web Services cloud (recommended, it is faster) # Imports: import requests import json import shutil import time import gzip import os # ==================================================================================== # Step 1: token request #proxy setting os.environ["HTTPS_PROXY"] = "http://proxy:8080" reqStart = "https://selectapi.datascope.refinitiv.com/RestApi/v1" requestUrl = reqStart + "/Authentication/RequestToken" requestHeaders = { "Prefer": "respond-async", "Content-Type": "application/json" } requestBody = { "Credentials": { "Username": myUsername, "Password": myPassword } } r1 = requests.post(requestUrl, json=requestBody, headers=requestHeaders) if r1.status_code == 200: jsonResponse = json.loads(r1.text.encode('ascii', 'ignore')) token = jsonResponse["value"] print('Authentication token (valid 24 hours):') print(token) else: print('Replace myUserName and myPassword with valid credentials, then repeat the request') # In[7]: # Step 2: send an on demand extraction request using the received token requestUrl = reqStart + '/Extractions/ExtractRaw' requestHeaders = { "Prefer": "respond-async", "Content-Type": "application/json", "Authorization": "token " + token } requestBody = { "ExtractionRequest": { "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.TickHistoryRawExtractionRequest", "IdentifierList": { "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentIdentifierList", "InstrumentIdentifiers": [{ "Identifier": "STXEc1", "IdentifierType": "Ric" }] }, "Condition": { "MessageTimeStampIn": "GmtUtc", "ReportDateRangeType": "Range", "QueryStartDate": "2021-08-20T12:00:00.000Z", "QueryEndDate": "2021-08-20T12:10:00.000Z", "Fids": "22,30,25,31,14265,1021", "ExtractBy": "Ric", "SortBy": "SingleByRic", "DomainCode": "MarketPrice", "DisplaySourceRIC": "true" } } } r2 = requests.post(requestUrl, json=requestBody, headers=requestHeaders) r3 = r2 # Display the HTTP status of the response # Initial response status (after approximately 30 seconds wait) is usually 202 status_code = r2.status_code print("HTTP status of the response: " + str(status_code)) # In[8]: # Step 3: if required, poll the status of the request using the received location URL. # Once the request has completed, retrieve the jobId and extraction notes. # If status is 202, display the location url we received, and will use to poll the status of the extraction request: if status_code == 202: requestUrl = r2.headers["location"] print('Extraction is not complete, we shall poll the location URL:') print(str(requestUrl)) requestHeaders = { "Prefer": "respond-async", "Content-Type": "application/json", "Authorization": "token " + token } # As long as the status of the request is 202, the extraction is not finished; # we must wait, and poll the status until it is no longer 202: while (status_code == 202): print('As we received a 202, we wait 30 seconds, then poll again (until we receive a 200)') time.sleep(30) r3 = requests.get(requestUrl, headers=requestHeaders) status_code = r3.status_code print('HTTP status of the response: ' + str(status_code)) # When the status of the request is 200 the extraction is complete; # we retrieve and display the jobId and the extraction notes (it is recommended to analyse their content)): if status_code == 200: r3Json = json.loads(r3.text.encode('ascii', 'ignore')) jobId = r3Json["JobId"] print('\njobId: ' + jobId + '\n') notes = r3Json["Notes"] print('Extraction notes:\n' + notes[0]) # If instead of a status 200 we receive a different status, there was an error: if status_code != 200: print('An error occured. Try to run this cell again. If it fails, re-run the previous cell.\n') # In[9]: # Step 4: get the extraction results, using the received jobId. # Decompress the data and display it on screen. # Skip this step if you asked for a large data set, and go directly to step 5 ! # We also save the data to disk; but note that if you use AWS it will be saved as a GZIP, # otherwise it will be saved as a CSV ! # This discrepancy occurs because we allow automatic decompression to happen when retrieving # from TRTH, so we end up saving the decompressed contents. # IMPORTANT NOTE: # The code in this step is only for demo, to display some data on screen. # Avoid using this code in production, it will fail for large data sets ! # See step 5 for production code. # Display data: # ZF print ('Decompressed data:\n' + uncompressedData) # Note: variable uncompressedData stores all the data. # This is not a good practice, that can lead to issues with large data sets. # We only use it here as a convenience for the demo, to keep the code very simple. # In[10]: # Step 5: get the extraction results, using the received jobId. # We also save the compressed data to disk, as a GZIP. # We only display a few lines of the data. # IMPORTANT NOTE: # This code is much better than that of step 4; it should not fail even with large data sets. # If you need to manipulate the data, read and decompress the file, instead of decompressing # data from the server on the fly. # This is the recommended way to proceed, to avoid data loss issues. # For more information, see the related document: # Advisory: avoid incomplete output - decompress then download requestUrl = requestUrl = reqStart + "/Extractions/RawExtractionResults" + "('" + jobId + "')" + "/$value" # AWS requires an additional header: X-Direct-Download if useAws: requestHeaders = { "Prefer": "respond-async", "Content-Type": "text/plain", "Accept-Encoding": "gzip", "X-Direct-Download": "true", "Authorization": "token " + token } else: requestHeaders = { "Prefer": "respond-async", "Content-Type": "text/plain", "Accept-Encoding": "gzip", "Authorization": "token " + token } r5 = requests.get(requestUrl, headers=requestHeaders, stream=True) # Ensure we do not automatically decompress the data on the fly: r5.raw.decode_content = False if useAws: print('Content response headers (AWS server): type: ' + r5.headers["Content-Type"] + '\n') # AWS does not set header Content-Encoding="gzip". else: print('Content response headers (TRTH server): type: ' + r5.headers["Content-Type"] + ' - encoding: ' + r5.headers[ "Content-Encoding"] + '\n') # Next 2 lines display some of the compressed data, but if you uncomment them save to file fails # print ('20 bytes of compressed data:') # print (r5.raw.read(20)) fileName = filePath + fileNameRoot + ".step5.csv.gz" print('Saving compressed data to file:' + fileName + ' ... please be patient') chunk_size = 1024 rr = r5.raw with open(fileName, 'wb') as fd: shutil.copyfileobj(rr, fd, chunk_size) fd.close print('Finished saving compressed data to file:' + fileName + '\n') # Now let us read and decompress the file we just created. # For the demo we limit the treatment to a few lines: maxLines = 10 print('Read data from file, and decompress at most ' + str(maxLines) + ' lines of it:') uncompressedData = "" count = 0 with gzip.open(fileName, 'rb') as fd: for line in fd: dataLine = line.decode("utf-8") # Do something with the data: print(dataLine) uncompressedData = uncompressedData + dataLine count += 1 if count >= maxLines: break fd.close() # Note: variable uncompressedData stores all the data. # This is not a good practice, that can lead to issues with large data sets. # We only use it here as a convenience for the next step of the demo, to keep the code very simple. # In production one would handle the data line by line (as we do with the screen display) # In[11]: # Step 6 (cosmetic): formating the response received in step 4 or 5 using a panda dataframe from io import StringIO import pandas as pd timeSeries = pd.read_csv(StringIO(uncompressedData)) timeSeries # In[ ]:
