Unable to download the extracted data using Tick History in R language
Client has followed the instructions on the below, however they are still unable to download the extracted data.
https://developers.refinitiv.com/en/article-catalog/article/using-tick-history-in-r-language-part-3
Below screenshot shows where they get 200 status, but when downloaded the data they get garbled code; below screenshot and their API details:
b='{
"ExtractionRequest": {
"@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.TickHistoryIntradaySummariesExtractionRequest",
"ContentFieldNames": [
"Close Ask",
"Close Bid",
"Volume"
"IdentifierList": {
"@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentIdentifierList",
"InstrumentIdentifiers": [
{ "Identifier": "IBM.N", "IdentifierType": "Ric" }
"ValidationOptions": null,
"UseUserPreferencesForValidationOptions": false
"Condition": {
"MessageTimeStampIn": "LocalExchangeTime",
"ReportDateRangeType": "Range",
"QueryStartDate": "2021-08-16T11:00:00.000Z",
"QueryEndDate": "2021-08-16T15:30:00.000Z",
"SummaryInterval": "OneMinute",
"TimebarPersistence": true,
"DisplaySourceRIC": true
#define a function to use later
RTHRawExtractionResults <- function(token,jobid,Path,Overwrite = TRUE) {
url <- paste0("https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/RawExtractionResults('",jobid,"')/$value")
r <- httr::GET(url,add_headers(prefer = "respond-async",Authorization = token),config(http_content_decoding=0),write_disk(Path,Overwrite),progress())
stop_for_status(r)
return(r)
#now define:
RTHExtractRaw <- function(token,b,path,overwrite = FALSE) {
url <- "https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/ExtractRaw"
r <- httr::POST(url,add_headers(prefer = "respond-async",Authorization = token),content_type_json(),body = b,encode = "json")
if (httr::status_code(r) == 202) {
message("The request has been accepted but has not yet completed executing asynchronously.\r\nReturn monitor URL\r\n",r$headers$location)
return(invisible(r$headers$location))
} else if(status_code(r) == 200) {
a<-content(r, "parsed", "application/json", encoding="UTF-8")
message(a$Notes)
return(RTHRawExtractionResults(token,a$JobID,path,overwrite))
} else {
warn_for_status(r)
return(a)
RTHExtractRaw(token,b,"C:/Users/Qi/OneDrive - UTS/_essay 2/Reuters sample/test.gzip")
#extraction not successful within 30s; get location url
path="C:/Users/Qi/OneDrive - UTS/_essay 2/Reuters sample/test.gzip"
location="https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/ExtractRawResult(ExtractionId='0x07ae2e2eb9fd0eee')"
#check for status until 200
r <- httr::GET(location,add_headers(prefer = "respond-async",Authorization = token))
r
RTHCheckRequestStatus <- function(token,location,path,overwrite = FALSE) {
r <- GET(location,add_headers(prefer = "respond-async",Authorization = token))
if (status_code(r) == 202) {
message("The request has not yet completed executing asynchronously.\r\nPlease wait a bit and check the request status again.\r\n")
message(a$Notes)
return(RTHRawExtractionResults(token,a$JobId,path,overwrite))
} else {
warn_for_status(r)
return(a)
RTHCheckRequestStatus(token,location,path,overwrite = TRUE)
@vinod.amarnath @Beera.Rajesh
tick-history-rest-api
23k 22 9 14
Hello @Vinod A ,
Please see this discussion thread and the last answer from @jirapongse.phuriphanvichai ,
does this help?
I think this may be a similar, of not the same, issue, i.e. try processing the result as a zip file?
