I'm looking at expired single stock dividend futures on Eurex,
I can find expired futures :
But there is no trading data :
Which is very surprising, can you check please ?
Best
Best
Hello @edbd and all,
Conveying the response from content experts:
"Please be informed that, Expired/Delisted securities will not be available or can be viewed via Datascope Select GUI (Graphical interface). Being a Tick History user, you need to run an extraction using Tick History Templates like Intraday Summaries, Time and Sales and RAW Report templates.
Hello @edbd ,
To investigate content discrepancies or other suspected content issues, the best approach for a customer is to raise these questions with Refinitiv content experts directly via Refinitiv Helpdesk Online -> Content -> RTH.
This forum can be of most help to you with questions and discussions centered around Refinitiv API usage.
In this case, I have raised the case on your behalf, case #10228287, please expect the follow-up via your email address that is registered on developers portal.
