Can anyone here see any mistake on the parameters? It just return nothing.
But it works if I change it to ssl.
/rmdstestclient -S $FEED -ct rssl -h $HOST -u $USER -v -f $RICLIST -X -d 3 -t 0
This could be a bug in rmdstestclient. Please use -l stdout option to print the XML to the standard output.
rmdstestclient -S $FEED -ct rssl -h $HOST -u $USER -v -f $RICLIST -X -d 3 -t 0 -l stdout
If rmdstestclient sends the source directory with serviceId="0", it means that rmdstestclient has this bug. You need to use the new version of rmdstestclient. You can get the new version of rmdstestlicent from ADS package.
<requestMsg rwfMajorVer="0" rwfMinorVer="0" mType="RWF_MT_SOURCE" streamId="2" dataFormat="RSSL_DF_NO_DATA" requestFlags="0x4" dataSize="0"> <key flags="0x9" serviceId="0" filter="255"/> <dataBody> </dataBody> </requestMsg> <refreshMsg rwfMajorVer="0" rwfMinorVer="0" mType="RWF_MT_SOURCE" streamId="2" dataFormat="RSSL_DF_MAP" refreshFlags="0x168" groupId ="0" dataState="RSSL_DATA_OK" streamState="RSSL_STREAM_OPEN" code="RSSL_SC_NONE" text="" dataSize="5"> <key flags="0x9" serviceId="0" filter="255"/> <dataBody> <map flags="0" countHint="0" keyDataType="RSSL_DT_UINT64" dataFormat="RSSL_DF_FILTER_LIST" > </map> </dataBody> </refreshMsg>
With this issue, the output from rmdstestclient is:
Received source directory response. No service status events received after five seconds. Service events should be returned immediately. Data cannot be requested until services are available.
