Using rmdstestclient for latency comparison across ADSs
We have pair of ADSs split across different data centers with each ADS receiving data locally from TREP.
I would like to do latency comparison across the ADSs using rmdstestclient (RSSL subscription) and capture the latency stats in a file. Which options in rmdstestclient are best suited for such comparison?
(The service is same but service name are different across the ADSs.)
Thank you.
elektronrefinitiv-realtimetrepinfrastructureADSrmds-test-clientlatency
11.5k 16 7 10
Hello @SMR
Please see the conversion regarding use rmdstestclient to monitor latency in this post.
As rmdstestclient is part of ADS server, I strongly suggest you contact the ADS support team via my.refinitiv.com to help on the rmdstestclient usage question.
