latest version of rmdstestclient
1) We use TREP as a managed service hence we are unable to get the latest version of rmdstestclient tool from the ADS package. Can the support team make the latest version (32/64-bit RHEL 6) available here for download?
2) Does rmdstestclient tool support providing multiple ADS hostname/IP? i.e. is there paramter to include ADS-1, ADS-2, etc.. in the rmdsastestclient? If connection to ADS-1 is down(for any reason), can the client tool auto reconnect to ADS-2?
Thank you for your help.
elektronrefinitiv-realtimetrepinfrastructurermds-test-client
4.4k 10 6 9
Hi @NWM
rmdstestclient and other TREP tools are available here as "TREP Infrastructure Tools" under "ELEKTRON SDK - TOOLS" section. But please note that the package contain 64-bit tools only.
rmdstestclient does not support failover.
However, it can connect to two ADSs at the same item, in order to measure latency between two ADSs. The list of command option is in the Test tools operation manual (Install.pdf).
@Warat, Thank you for your response and the links. It is helpful.
