I use the sample c# code, adding the api key and api secret. Call the get groups to get group id. Then call post cases to create a case with group id from previous call. This returns 401 unauthorized.
I use the same request body in postman and it works.
I notice some differences between postman and c# code. Postman has longer content length(171) than c# code generated(138) request. I don't know why.
Here is the request data from c# code
dataToSign = "(request-target): post/v2/cases\nhost: api-worldcheck.refinitiv.com\ndate: Fri, 09 Jul 2021 22:38:46 GMT\ncontent-type: application/json\ncontent-length: 138\n{\"entityType\":\"ORGANISATION\",\"groupId\":\"xxxxxxxxxxxxxxxxxxxxxxxxx\",\"provideTypes\":[\"WATCHLIST\"],\"name\":\"Lajnat ul Masa Eidatul Afghaniab\"}"
authorisation = "Signature keyId=\"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date content-type content-length\",signature=\"vf7X29JltDSWMW938DwfnC6qW7A8XKrjCGHdDkczW9Y=\""
Please assist.
Thank you,
Cady
