Results, how to get other details
Pulling Case results, how to include Gender, DoB, Identification, country location, type and category?
world-checkworld-check-onecase
3.1k 16 7 7
Hi @Angelo.Panares.1,
There are two API request regarding a case, there is case details and match details.The screening match will return match information for the fields you entered, if you want more information then you select the match you want and use its worldcheck-profile-id and request the WC1 profile. That will have all the known information about the match.
{ {protocol}}{ {gateway-host}}{ {gateway-url}}reference/profile/{ {worldcheck-profile-id}}
Hope this helps,
Brian
