When I executed the following script on CodeBook using RDP Libraries, I could plot a 3D chart of volatility surface, but I can NOT do so today having the following error message.
Can you please let me know the root cause of the error and how to resolve it?
INPUT:
import refinitiv.dataplatform as rdp import pandas as pd import numpy as np import matplotlib.pyplot as plt from mpl_toolkits.mplot3d import axes3d, Axes3D import matplotlib.cm as cm %matplotlib inline session = rdp.open_desktop_session('DEFAULT_CODE_BOOK_APP_KEY') endpoint = rdp.Endpoint(session, "https://api.refinitiv.com/data/quantitative-analytics-curves-and-surfaces/v1/surfaces") request_body={ "universe": [ { "surfaceTag": "RENAULT", "underlyingType": "Eti", "underlyingDefinition": { "instrumentCode": "RENA.PA" }, "surfaceParameters": { "inputVolatilityType": "settle", "volatilityModel": "SSVI", "xAxis": "Date", "yAxis": "Moneyness" }, "surfaceLayout": { "format": "Matrix" } }, { "surfaceTag": "PEUGEOT", "underlyingType": "Eti", "underlyingDefinition": { "instrumentCode": "PEUP.PA" }, "surfaceParameters": { "inputVolatilityType": "settle", "volatilityModel": "SSVI", "xAxis": "Date", "yAxis": "Moneyness" }, "surfaceLayout": { "format": "Matrix" } }, { "surfaceTag": "BMW", "underlyingType": "Eti", "underlyingDefinition": { "instrumentCode": "BMWG.DE" }, "surfaceParameters": { "inputVolatilityType": "settle", "volatilityModel": "SSVI", "xAxis": "Date", "yAxis": "Moneyness" }, "surfaceLayout": { "format": "Matrix" } }, { "surfaceTag": "VW", "underlyingType": "Eti", "underlyingDefinition": { "instrumentCode": "VOWG.DE" }, "surfaceParameters": { "inputVolatilityType": "settle", "volatilityModel": "SSVI", "xAxis": "Date", "yAxis": "Moneyness" }, "surfaceLayout": { "format": "Matrix" } }] } response = endpoint.send_request( method = rdp.Endpoint.RequestMethod.POST, body_parameters = request_body ) def convert_yyyymmdd_to_float(time_axis): float_time_axis = [] for time in time_axis: time = time.replace('-', '') float_time_axis.append(float(time)) return float_time_axis def plot_surface(surfaces, surfaceTag): #various imports removed for brevity surfaces = pd.DataFrame(data=surfaces) surfaces.set_index('surfaceTag', inplace=True) surface = surfaces[surfaces.index == surfaceTag]['surface'][0] strike_axis = surface[0][1:] surface = surface[1:] time_axis = [] surface_grid = [] for line in surface: time_axis.append(line[0]) surface_grid_line = line[1:] surface_grid.append(surface_grid_line) time_axis = convert_yyyymmdd_to_float(time_axis) x = np.array(strike_axis, dtype=float) y = np.array(time_axis, dtype=float) ero = np.array(surface_grid, dtype=float) X,Y = np.meshgrid(x,y) Z = ero fig = plt.figure(figsize=[15,10]) ax = plt.axes(projection='3d') ax.set_xlabel('moneyness') ax.set_ylabel('time to expiry') ax.set_zlabel('volatilities') surf = ax.plot_surface(X,Y,Z, cmap=cm.coolwarm, linewidth=0, antialiased=False) plt.show() surfaces = response.data.raw['data'] plot_surface(surfaces, 'VW')
OUTPUT:
--------------------------------------------------------------------------- KeyError Traceback (most recent call last) /opt/conda/lib/python3.7/site-packages/pandas/core/indexes/base.py in get_loc(self, key, method, tolerance) 2894 try: -> 2895 return self._engine.get_loc(casted_key) 2896 except KeyError as err: pandas/_libs/index.pyx in pandas._libs.index.IndexEngine.get_loc() pandas/_libs/index.pyx in pandas._libs.index.IndexEngine.get_loc() pandas/_libs/hashtable_class_helper.pxi in pandas._libs.hashtable.PyObjectHashTable.get_item() pandas/_libs/hashtable_class_helper.pxi in pandas._libs.hashtable.PyObjectHashTable.get_item() KeyError: 'surface' The above exception was the direct cause of the following exception: KeyError Traceback (most recent call last) <ipython-input-35-aa5486f52eab> in <module> 1 surfaces = response.data.raw['data'] ----> 2 plot_surface(surfaces, 'VW') 3 # plot_surface(surfaces, 'BMW') <ipython-input-16-d9df2e95c642> in plot_surface(surfaces, surfaceTag) 10 surfaces = pd.DataFrame(data=surfaces) 11 surfaces.set_index('surfaceTag', inplace=True) ---> 12 surface = surfaces[surfaces.index == surfaceTag]['surface'][0] 13 14 strike_axis = surface[0][1:] /opt/conda/lib/python3.7/site-packages/pandas/core/frame.py in __getitem__(self, key) 2904 if self.columns.nlevels > 1: 2905 return self._getitem_multilevel(key) -> 2906 indexer = self.columns.get_loc(key) 2907 if is_integer(indexer): 2908 indexer = [indexer] /opt/conda/lib/python3.7/site-packages/pandas/core/indexes/base.py in get_loc(self, key, method, tolerance) 2895 return self._engine.get_loc(casted_key) 2896 except KeyError as err: -> 2897 raise KeyError(key) from err 2898 2899 if tolerance is not None: KeyError: 'surface'
INPUT:
surfaces
OUTPUT:
[{'surfaceTag': 'RENAULT', 'error': {'id': '3b6ecb24-f876-4b9c-a965-9e05400fb629/e7b8fa38-c5b3-40b3-b1bb-8f7fad66fcde', 'status': 'Error', 'message': 'The service failed to build the volatility surface', 'code': 'VolSurf.10300'}}, {'surfaceTag': 'PEUGEOT', 'error': {'id': '3b6ecb24-f876-4b9c-a965-9e05400fb629/4b652a29-ff3b-4277-9e44-d933273c8888', 'status': 'Error', 'message': 'Unknown underlying : PEUP.PA@RIC', 'code': 'VolSurf.10008'}}, {'surfaceTag': 'BMW', 'error': {'id': '3b6ecb24-f876-4b9c-a965-9e05400fb629/854b01f4-a046-4340-a16e-8b5830496185', 'status': 'Error', 'message': 'The service failed to build the volatility surface', 'code': 'VolSurf.10300'}}, {'surfaceTag': 'VW', 'error': {'id': '3b6ecb24-f876-4b9c-a965-9e05400fb629/2bee51a2-780f-40db-871b-15cdb883fc41', 'status': 'Error', 'message': 'The service failed to build the volatility surface', 'code': 'VolSurf.10300'}}]
