Hello..
I tried to execute "2.3.0 - Content - StreamingPrices - Update DataFrame". I could data via Eikon and EDP but not from TREP. I just got
<StreamState.Open: 3>
then no updates.
Could you give me a hint to debug the situation?
Hello..
then no updates.
I got the same message but after adding the correct TCP port, it works.
rdp.open_deployed_platform_session( "<app key>", "192.168.27.16:15000", "user01" )
15000 is my TREP port for WebSocket.
You can also try out the alternative examples under Developer Day Resources
These examples use my Session helper class which also outputs session events and status information - which may provide useful information.
In addition to this you can enable logging for the session in case you need additional diagnostics e.g.
mySession = get_session("deployed") #mySession.set_log_level(6) mySession.open()
