I am currently trying to retrieve streaming news for RDP platform.
When I run the following code in a jupyter notebook cell all is working fine :
import refinitiv.dataplatform as rdp import datetime import zlib import base64 import json APP_KEY = '***' MACHINE_ID = '***' PASSWD = '***' rdp.open_platform_session(app_key=APP_KEY, grant=rdp.GrantPassword(username=MACHINE_ID, password=PASSWD) ) item_stream = rdp.ItemStream(session=rdp.get_default_session(), domain=DOMAIN, name=NAME, #should be optional on_refresh = lambda item_stream, event : processMRNstart("Refresh", event), on_update = lambda item_stream, event : processMRNUpdate("Update", event), on_status = lambda item_stream, event : processMRNstart("Status", event), on_complete = lambda item_stream : processMRNstart("Complete", "") ) item_stream.open()
However, when I copy paste this code into a python script .py and run in into the command shell it stucks around the rpd.open_platform_session function and nothing happens.
Any ideas about the different behavior between Jupyter notebook and Python scripts for getteting streaming news from RDP platform ?
