GetValidExtractionFieldNamesAsync broken in DataScope Select C# REST API
I am using the latest version of the C# Rest API (14.5.72). It is unable to make a request to get valid field names (GetValidExtractionFieldNamesAsync) due to a namespacing error (ThomsonReuters vs DataScope.Select).
dss-rest-apidatascope-selectdssc#
@stephen.drew
@VladVM
Have you changed an endpoint to "https://selectapi.datascope.refinitiv.com/RestApi/v1/"?
Uri dssUri = new Uri("https://selectapi.datascope.refinitiv.com/RestApi/v1/")
string dssUserName = "YourUserId
string dssUserPassword = "YourPassword"
ExtractionsContext extractionsContext = new ExtractionsContext(dssUri, dssUserName, dssUserPassword);
Same for InstrumentListOperations.Create(...) and ReportTemplateOperations.Create(...) and GetByName(...)
DataScope.Select.Api.ValidationException
HResult=0x80131500
Message=Malformed request payload: Unexpected @odata.type 'ThomsonReuters.Dss.Api.Extractions.SubjectLists.DataScope.Select.Api.Extractions.SubjectLists.InstrumentList' in payload
Source=ThomsonReuters.Dss.RestApi.Client
StackTrace:
at DataScope.Select.Api.Core.HttpOData.Http.HttpClientExceptionDecorator.<ParseResponseError>d__1b.MoveNext()
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at DataScope.Select.Api.Core.HttpOData.Http.HttpClientExceptionDecorator.<HandleExceptions>d__11.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at DataScope.Select.Api.Core.HttpOData.Http.HttpAsyncJobStrategy.<InvokeAsync>d__0.MoveNext()
at DataScope.Select.Api.Core.HttpOData.HttpODataClient.<PostAsync>d__3e.MoveNext()
at DataScope.Select.Api.Core.OperationsBaseForHttpODataClient.<>c__DisplayClass103.<<CallOnHttpODataClient>b__102>d__105.MoveNext()
at DataScope.Select.Api.Core.OperationsBaseForHttpODataClient.<CallOnHttpODataClient>d__10b`1.MoveNext()
at DataScope.Select.Api.Core.OperationsBaseForHttpODataClient.<CallOnHttpODataClient>d__108.MoveNext()
at DataScope.Select.Api.Core.Helper.<ReAuthenticateIfNecessaryAsync>d__3.MoveNext()
at DataScope.Select.Api.Core.OperationsBaseForHttpODataClient.<PostAsync>d__64.MoveNext()
at DataScope.Select.Core.RestApi.Threading.Tasks.AsyncHelper.RunSync(Func`1 func)
at DataScope.Select.Api.Core.Helper.InvokeSynchronously(Func`1 action)
at Dss.Api.Examples.Extractions.ReportExtractions.ReportExtractionExamples.GetCompletedByDateRange() in C:\Source\PlayRoom\Refinitiv\Extractions\ReportExtractions\ReportExtractionExamples.cs:line 140
This exception was originally thrown at this call stack:
[External Code]
Dss.Api.Examples.Extractions.ReportExtractions.ReportExtractionExamples.GetCompletedByDateRange() in ReportExtractionExamples.cs
HResult=0x80131500
Message=Malformed request payload: Unexpected @odata.type 'ThomsonReuters.Dss.Api.Extractions.ReportTemplates.DataScope.Select.Api.Extractions.ReportTemplates.EndOfDayPricingReportTemplate' in payload
StackTrace:
at Dss.Api.Examples.Extractions.ReportTemplates.ReportTemplateExamples.GetReportTemplateByName() in C:\Source\PlayRoom\Refinitiv\Extractions\ReportTemplates\ReportTemplateExamples.cs:line 94
[External Code]
Dss.Api.Examples.Extractions.ReportTemplates.ReportTemplateExamples.GetReportTemplateByName() in ReportTemplateExamples.cs
