Tick History Client want their GUI custom extractions output files downloaded to their system automatically with no manual intervention. As Tick History does not support FTP, looking for a way to do the same through API
I found this way:
Step1: Check for files available for download:
END POINT: https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractedFiles
HEADERS:
Authorization:Token <Token Value>
Prefer:odata.track-changes; respond-async; odata.maxpagesize=25
Step 2: Download the output file using "ExtractedFileId": "VjF8fDc5NzI3MDI2OQ",
END POINT: https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractedFiles('VjF8fDc5NzI3MDI2OQ')/$value
HEADERS:
Prefer:respond-async
Content-Type:application/json
Accept-Encoding:gzip, deflate
But Extractions/ExtractedFiles is giving full list of files (historical and current day) every time we do this call will cause duplicate downloads, Is there a way to get output files by date / any other API call which looks for current day extractions and download the available files.
tick-history-rest-api
@Beera.Rajesh
I think the client can use /Extractions/ReportExtractionGetCompletedByDateRange(StartDate=2021-03-23T00:00:00.000Z,EndDate=2021-03-23T23:59:00.000Z) to get all extractions Pending, Processing, or Completed that match the specified date range.
It will return the ReportExtractionId.
            "ReportExtractionId": "515075714",
            "ScheduleId": "0x077cf62db1e75b7a",
            "Status": "Completed",
            "DetailedStatus": "Done",
            "ExtractionDateUtc": "2021-03-23T08:40:51.503Z",
            "ScheduleName": "03.23.2021 08.40.28",
            "IsTriggered": false,
            "ExtractionStartUtc": "2021-03-23T08:40:52.000Z",
            "ExtractionEndUtc": "2021-03-23T08:40:55.000Z"
Then, use the ReportExtractionId with Extractions/ReportExtractions('515075714')/Files to get files.
            "ExtractedFileId": "VjF8fDc5NzY1NzY1Ng",
            "FileType": "RicMaintenanceNote",
            "ExtractedFileName": "testextractedfile1.ric.csv",
            "LastWriteTimeUtc": "2021-03-23T08:40:55.432Z",
            "ContentsExists": true,
            "Size": 0,
            "ReceivedDateUtc": "2021-03-23T08:40:55.432Z"
            "ExtractedFileId": "VjF8fDc5NzY1NzY1NQ",
            "FileType": "Full",
            "ExtractedFileName": "testextractedfile1.csv",
            "LastWriteTimeUtc": "2021-03-23T08:40:55.423Z",
            "Size": 105,
            "ReceivedDateUtc": "2021-03-23T08:40:55.423Z"
            "ExtractedFileId": "VjF8fDc5NzY1NzY1NA",
            "FileType": "Note",
            "ExtractedFileName": "testextractedfile1.csv.notes.txt",
            "LastWriteTimeUtc": "2021-03-23T08:40:55.437Z",
            "Size": 1544,
            "ReceivedDateUtc": "2021-03-23T08:40:55.437Z"
@jirapongse.phuriphanvichai Thank you.
Please confirm if the final call is to use "ExtractedFileId": "VjF8MHgwNzdkNjVlODU0Nzc1YzVifA", to download related files?
<https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ReportExtractions('2000000239094096')/Files >
@Beera.Rajesh
Yes, you can use the ExtractedFileId to get the file.
Extractions/ExtractedFiles('VjF8fDc5NzY1NzY1NQ')/$value
