Greeting everyone
Do we have a TRTH API help file (like F1 help) for all functions and parameters?
Thank you in advance.
Greeting everyone
I can't find any reference to a F1 help, however help for TRTH can be found on the Documentation tab of the TRTH pages on the developer Portal
You can also access help from the TRTH login page Thomson Reuters Tick History Help
Umer
For TRTH - SOAP API, you can use the SOAPUI tool to create these HTTP/SOAP/XML Function calls manually and test them easily, as mentioned in the TRTH - SOAP API Documentation.
