Raw Legacy Market Depth how to get?
Please tell me.
There is a code how you can get the history in the format "Raw Legacy Market Depth"
please help!
code:
using System;
using System.Linq;
using System.Diagnostics;
using System.IO;
using ThomsonReuters.Dss.Api.StandardExtractions;
using ThomsonReuters.Dss.Api;
using ThomsonReuters.Dss.Api.Content;
using ThomsonReuters.Dss.Api.Extractions;
using ThomsonReuters.Dss.Api.Extractions.ExtractionRequests;
using ThomsonReuters.Dss.Api.Extractions.ReportExtractions;
using ThomsonReuters.Dss.Api.Extractions.ReportTemplates;
using ThomsonReuters.Dss.Api.Extractions.Schedules;
using ThomsonReuters.Dss.Api.Extractions.SubjectLists;
using ThomsonReuters.Dss.Api.Search;
using ThomsonReuters.Dss.Core.RestApi;
namespace RefinitivHistoryTesting
    class Program
        static void Main(string[] args)
            //Connect and authenticate to the DSS server:
            Uri dssUri = new Uri("https://hosted.datascopeapi.reuters.com/RestApi/v1/");
            string dssUserName = "******";
            string dssUserPassword = "*****";
            var out_dir = @".\Storage\";
            var SearchContext = new SearchContext(dssUri, dssUserName, dssUserPassword);
            var ExtractionsContext = new ExtractionsContext(dssUri, dssUserName, dssUserPassword);
            var availableMbPFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryRaw);
          //var availableLL2Fields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryMarketDepth);
            var availableTnSFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryTimeAndSales);
            ExtractionsContext.Options.AutomaticDecompression = true;
            var dateRange = DateTimeRange.Create(
                new DateTimeOffset(2008, 01, 01, 0, 0, 0, TimeSpan.Zero),
                new DateTimeOffset(2020, 12, 22, 0, 0, 0, TimeSpan.Zero));
            var request = new HistoricalChainResolutionRequest
                ChainRics = new[] { "0#ES:" },//{ "0#1URO:" },
                Range = dateRange
            var chain_results = SearchContext.HistoricalChainResolution(request);
            foreach (var chain in chain_results)
                Console.WriteLine("Chain Identifier: {0} {1}, Constituents: {2}", chain.IdentifierType, chain.Identifier, chain.Constituents.Count());
                foreach (var constituent in chain.Constituents)
                    var searchResults = SearchContext.HistoricalSearch(
                        HistoricalSearchRequest.Create(
                            constituent.Identifier, constituent.IdentifierType, dateRange, HistoricalResultsBy.Ric, null));
                    //foreach (var result in from pos in searchResults where pos.DomainCode == "8" select pos)
                    foreach (var result in searchResults)
                    //var result = searchResults.FirstOrDefault(pos => pos.Identifier.Contains("UROH1"));
                    //if (result != null)
                        var startDate = result.FirstDate;
                        var lastDate = result.LastDate;
                        Console.WriteLine("{0},\t {1},\t {2},\t {3},\t {4}", result.Identifier, result.IdentifierType, startDate, lastDate, result.DomainCode);
                        var extractionResult = ExtractionsContext.ExtractRaw(
                                //!!!--- Это должно соответствовать модели данных Real Time API MarketByPrice---!!!
                                new TickHistoryRawExtractionRequest
                                    Condition = new TickHistoryRawCondition
                                        ReportDateRangeType = ReportDateRangeType.Range,
                                        QueryStartDate = startDate, //new DateTimeOffset(2016, 07, 25, 20, 0, 0, TimeSpan.Zero),
                                        QueryEndDate = lastDate, //new DateTimeOffset(2016, 08, 02, 19, 59, 59, TimeSpan.Zero),
                                        ExtractBy = TickHistoryExtractByMode.Ric,
                                        MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc,
                                        SortBy = TickHistorySort.SingleByRic,
                                        DomainCode = TickHistoryRawDomain.MarketByPrice,
                                        DisplaySourceRIC = true
                                    IdentifierList = new InstrumentIdentifierList
                                        InstrumentIdentifiers = new[]
                                            InstrumentIdentifier.Create(result.IdentifierType, result.Identifier)
                                        ValidationOptions = new InstrumentValidationOptions
                                            AllowHistoricalInstruments = true
                        new TickHistoryMarketDepthExtractionRequest
                            Condition = new TickHistoryMarketDepthCondition
                                NumberOfLevels = 10,
                                View = TickHistoryMarketDepthViewOptions.NormalizedLL2,
                            ContentFieldNames = availableLL2Fields.Select(f => f.Name).ToArray(),
                                    InstrumentIdentifier.Create( result.IdentifierType, result.Identifier)
                        using (var response = ExtractionsContext.RawExtractionResultOperations.GetReadStream(extractionResult))
                        using (var reader = new StreamReader(response.Stream))
                            var fileName = out_dir + "_" + result.Identifier + "_" + startDate.DateTime.ToString("dd.MM.yyyy") + "_" + lastDate.DateTime.ToString("dd.MM.yyyy") + "_MarketByPrice.txt";
                            using (var fileStream = File.Create(fileName))
                                response.Stream.CopyTo(fileStream);
            Console.WriteLine("Press Enter to exit");
            Console.ReadLine();
tick-history-rest-api
@s61670
If you mean getting LegacyLevel2 with TickHistoryMarketDepthExtractionRequest, the code looks like the following.
                     View = TickHistoryMarketDepthViewOptions.LegacyLevel2,
                     ValidationOptions = new InstrumentValidationOptions {
