cut file, file 0 kb
Please tell me the answer to who worked with such problems
Using an API example to access Tick History
For example: RIC ESH1 (raw market-by-price)
Something does not download the full contract from the start date to the current date.
Cuts the file size.
How to download the contract completely so that the dates inside the file do not cut?
So for example, why 1UROF0, 1UROF1, 1UROF8, 1UROF9, 1UROG0, 1UROG1 file size 0 kb
Why?
code:
using System;
using System.Linq;
using System.Diagnostics;
using System.IO;
using ThomsonReuters.Dss.Api.StandardExtractions;
using ThomsonReuters.Dss.Api;
using ThomsonReuters.Dss.Api.Content;
using ThomsonReuters.Dss.Api.Extractions;
using ThomsonReuters.Dss.Api.Extractions.ExtractionRequests;
using ThomsonReuters.Dss.Api.Extractions.ReportExtractions;
using ThomsonReuters.Dss.Api.Extractions.ReportTemplates;
using ThomsonReuters.Dss.Api.Extractions.Schedules;
using ThomsonReuters.Dss.Api.Extractions.SubjectLists;
using ThomsonReuters.Dss.Api.Search;
using ThomsonReuters.Dss.Core.RestApi;
namespace RefinitivHistoryTesting
    class Program
        static void Main(string[] args)
            //Connect and authenticate to the DSS server:
            Uri dssUri = new Uri("https://hosted.datascopeapi.reuters.com/RestApi/v1/");
            string dssUserName = "****";
            string dssUserPassword = "*****";
            var out_dir = @".\Storage\";
            var SearchContext = new SearchContext(dssUri, dssUserName, dssUserPassword);
            var ExtractionsContext = new ExtractionsContext(dssUri, dssUserName, dssUserPassword);
            var availableMbPFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryRaw);
            var availableTnSFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryTimeAndSales);
            ExtractionsContext.Options.AutomaticDecompression = true;
            var dateRange = DateTimeRange.Create(
                new DateTimeOffset(2008, 01, 01, 0, 0, 0, TimeSpan.Zero),
                new DateTimeOffset(2020, 12, 22, 0, 0, 0, TimeSpan.Zero));
            var request = new HistoricalChainResolutionRequest
                ChainRics = new[] { "0#1URO:" },//{ "0#ESH1m" },//{ "0#1URO:" },
                Range = dateRange
            var chain_results = SearchContext.HistoricalChainResolution(request);
            foreach (var chain in chain_results)
                Console.WriteLine("Chain Identifier: {0} {1}, Constituents: {2}", chain.IdentifierType, chain.Identifier, chain.Constituents.Count());
                foreach (var constituent in chain.Constituents)
                    var searchResults = SearchContext.HistoricalSearch(
                        HistoricalSearchRequest.Create(
                            constituent.Identifier, constituent.IdentifierType, dateRange, HistoricalResultsBy.Ric, null));
                    //foreach (var result in from pos in searchResults where pos.DomainCode == "8" select pos)
                    foreach (var result in searchResults) // выкачивает 8 и 6, если имя контракта или все файлы если chain
                    //var result = searchResults.FirstOrDefault(pos => pos.Identifier.Contains("1UROF0") &&pos.DomainCode=="8");
                    //if (result != null)
                        var startDate = result.FirstDate;//new DateTimeOffset(2021, 01, 01, 0, 0, 0, TimeSpan.Zero);//result.FirstDate;
                        var lastDate = result.LastDate;//new DateTimeOffset(2021, 03, 05, 0, 0, 0, TimeSpan.Zero);//result.LastDate;
                        Console.WriteLine("{0},\t {1},\t {2},\t {3},\t {4}", result.Identifier, result.IdentifierType, startDate, lastDate, result.DomainCode);
                        var extractionResult = ExtractionsContext.ExtractRaw(
                                //!!!--- Это должно соответствовать модели данных Real Time API MarketByPrice---!!!
                                new TickHistoryRawExtractionRequest
                                    Condition = new TickHistoryRawCondition
                                        ReportDateRangeType = ReportDateRangeType.Range,
                                        QueryStartDate = startDate, //new DateTimeOffset(2016, 07, 25, 20, 0, 0, TimeSpan.Zero),
                                        QueryEndDate = lastDate, //new DateTimeOffset(2016, 08, 02, 19, 59, 59, TimeSpan.Zero),
                                        ExtractBy = TickHistoryExtractByMode.Ric,
                                        MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc,
                                        SortBy = TickHistorySort.SingleByRic,
                                        DomainCode = TickHistoryRawDomain.MarketByPrice,
                                        DisplaySourceRIC = true
                                    IdentifierList = new InstrumentIdentifierList
                                        InstrumentIdentifiers = new[]
                                            InstrumentIdentifier.Create(result.IdentifierType, result.Identifier)
                        using (var response = ExtractionsContext.RawExtractionResultOperations.GetReadStream(extractionResult))
                        using (var reader = new StreamReader(response.Stream))
                            var fileName = out_dir + "_" + result.Identifier + "_" + startDate.DateTime.ToString("dd.MM.yyyy") + "_" + lastDate.DateTime.ToString("dd.MM.yyyy") + "_MarketByPrice.txt";
                            using (var fileStream = File.Create(fileName))
                                response.Stream.CopyTo(fileStream);
            Console.WriteLine("Press Enter to exit");
            Console.ReadLine();
tick-history-rest-api
23k 22 9 14
Hello @s61670,
I just looked into one RIC, "1UROF0". To some it up, I think this will require an input from an RTH content expert, as not all instruments in all markets have Raw history stored.
1. HistoricalChainResolution Chain "0#1URO:" expands, RIC "1UROF0" is present
2. HistoricalSearch Ric 1UROF0,
  "Request": {
    "Identifier": "1UROF0",
    "IdentifierType": "Ric",
    "Range": {
      "Start": "2008-01-01T00:00:00.000Z",
      "End": "2021-01-01T00:00:00.000Z"
results:
"value": [
            "Source": "",
            "Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHwxVVJPRjB8",
            "Description": "Historical Instrument",
            "InstrumentType": "Unknown",
            "Status": "Valid",
            "DomainCode": "6",
            "FirstDate": "2019-08-17T00:00:00.000Z",
            "LastDate": "2020-01-25T00:00:00.000Z",
            "History": []
            "Source": "",
            "Status": "Valid",
            "DomainCode": "8",
            "FirstDate": "2019-08-05T00:00:00.000Z",
            "History": []
3. Therefore, we can request raw history "1UROF0":
  "ExtractionRequest": {
    "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryRawExtractionRequest",
    "IdentifierList": {
      "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList",
      "InstrumentIdentifiers": [{
      "ValidationOptions": null,
      "UseUserPreferencesForValidationOptions": false
    "Condition": {
      "MessageTimeStampIn": "GmtUtc",
      "ReportDateRangeType": "Range",
      "QueryStartDate": "2019-08-05T00:00:00.000Z",
      "QueryEndDate": "2020-01-25T00:00:00.000Z",
      "ExtractBy": "Ric",
      "SortBy": "SingleByRic",
      "DomainCode": "MarketPrice",
      "DisplaySourceRIC": true
That results in:
    "@odata.context": "https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#RawExtractionResults/$entity",
    "JobId": "0x077752f443174f26",
    "Notes": [
        "All identifiers were invalid.  No extraction performed."
    "IdentifierValidationErrors": [
            "Identifier": {
                "@odata.type": "#ThomsonReuters.Dss.Api.Content.InstrumentIdentifier",
                "Source": ""
            "Message": "Not found"
It is likely that only some data for this instrument (and other instruments from your list) is made available as Raw history. There is a possibility that you have run into a content gap that is not intentional. However, to tell for sure, would need an RTH content expert, and this forum is mainly comprised of developers, the members of the forum are developers working with Refinitiv APIs, the moderators are Refinitiv API experts.
For a content question such as this, the best approach for a Refinitiv customer is to submit it directly, to Refinitiv Helpdesk Online -> Tick History, or by dialing Refinitiv Helpdesk local number.
In this case, we are going to refer to content experts for investigation, and get back to you and the community here.
The screen shows that the file is being cut.
Full RIC history is not downloaded
There is no current date, the number of lines is more than 13 million.
Other RICs are downloaded empty without data. What could be the problem?
