Failed - Step 02 -SEQ-case-create-simple: Save a very simple case
I got error on step 2 SEQ-case-create-simple: Save a very simple case below mentioned quick-start
https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api/quick-start
Error :
Body :
here step 1 has been succeed.
So, what issue here and how can I solve it?
Thank you
world-checkworld-check-onecase
4.5k 4 7 8
@ksenanayake1,
Thank you for your query.
Can you please share the request and the response headers of the failed API call?
@Prabhjyot
this is the image of request and response header
@Prabhjyot
today i got a error (500 error code) in first step as well
SEQ-1a - groups Web Service - "Get my top-level groups"
but it worked yesterday
what is the reason behind it?
@ksenanayake1,
Can you please share the request and the response headers as in postman console logs? Go to View and select - 'Postman console logs'.
We need to see the action header values which are being passed and returned.
@prabhjyot.mandla
solved the first step right now. it is working
thank you,
But step 2 still has an error(401)
@ksenanayake1,
Can you please share the dataToSign format from the pre request script?
@prabhjyot.mandla
var dataToSign = "(request-target): post " + environment["gateway-url"] + "cases\n" +
"host: " + environment["gateway-host"] + "\n" +
"date: " + date + "\n" +
"content-type: " + environment["content"] +"\n" +
"content-length: " + contentLength + "\n" +
content;
