Adjusted EQ Prices
Hi Refintiv Support,
I would like to download adjusted EQ Spot price history. Can you give me example of what the payload will look like? Basically, where to add the "IsAdjusted" boolean field.
Regards,
josa
dss-rest-apidatascope-selectdssjava
Thanks @zoya.farberov.
I found out from one of your SME that the field is: "Adjustment Value - Capital Change".
Please close this ticket.
Thanks,
josa
23k 22 9 14
Hello @josa,
Please review this previous discussion thread.
Does this help to answer your question?
How will I get the split factor then?
josa
23k 22 9 14
Hello @josa,
This is an excellent question. I have just reviewed the spec for PriceHistory template and I do not see split factor listed.
That does not mean that this content is not available.
This forum is intended for developers and targets general questions and discussions centered around the usage of Refinitiv APIs, the majority of the members are developers working with Refinitiv APIs, the moderators are API experts, so this audience will not have in-depth expertise in various areas of Refinitiv content.
As a developer, there is a quick way to review all the fields that are available, via "List all fields request and via Content Guide, please see this discussion thread for the discussion of these two ways (this is what I just did for your question)
As a customer, if you do not see the content you are looking for in the reference, the best action is to open a content inquiry via Refinitiv Content Helpdesk Online and to provide all the details of the content you are looking for, so it can be assigned to the appropriate content expert team within Refinitiv.
I hope this answer helps
