org.json.JSONOrderedObject Java library
First of all, this is my first JSON in Java experience.
I was getting 400 - bad request for extraction call (/Extractions/Extract). Then I've tried to sent just a json string with property order exactly as it was in the example and it was working. A bit tricky.
I don't think my library (com.googlecode.json-simple) can maintain the property order within a JSONObject. In the API's Java examples there's a org.json.JSONOrderedObject - I was not able to find out which JSON library contains this class.
Thanks for any advice.
Filip
dss-rest-apidatascope-selectdssjavajsonjar
Ok, now I see these classes are included within the examples.
Anyway I was hoping for more "Maven" way - I don't feel comfortable neither including this 3rd party to my source code nor creating and deploying artifact from those.
I've resolved the issue with this simple work-around, still using json-simple, but substituting standard HashMap with LinkedHashMap.
public class JSONOrderedObject extends LinkedHashMap<String, Object> implements Map<String, Object>, JSONAware, JSONStreamAware {
@Overridepublic String toJSONString() {
return JSONObject.toJSONString(this);}
@Overridepublic void writeJSONString(Writer writer) throws IOException {
JSONObject.writeJSONString(this, writer);}
I have the same problem: I would like use something more "Maven".
I found org.springframework.boot.configurationprocessor.json.JSONObject which internally uses a LinkedHashMap.
maven dependency:
<groupId>org.springframework.boot</groupId>
<artifactId>spring-boot-configuration-processor</artifactId>
<version>2.3.12.RELEASE</version>
However I was wondering if anyone else is using something different and why.
13.7k 26 8 12
@filip.balas
If you download the Java code examples from the downloads tab, you will find the libraries we used, under \DSS2_Java_Examples\src\org\json.
Note these Java samples are currently being rewritten to make them easier to understand. The first one in the new style is DSS2SearchFirRICClientV2.java. The others will come soon.
Sample rewrite is finished, the new versions are now available for download here.
9.5k 10 5 7
Based on JSONOrderedObject source code, it seem that the class is written using pure java classes(no using any JSON library classs) as shown below:
@filip.balas
Thanks for sharing your work around solution. That's great! The org.json.JSONOrderedObject class is a modified version of the org.json.JSONObject, to help maintain the order of the properties in the JSON request object (yes, as you noted, the exact order of the properties is required for most of the requests). The main difference is the org.json.JSONOrderedObject class uses LinkedHashMap instead on Map.
