Is this the first time you are running this code or are is this existing code suddenly generating errors? Nope it has running since ages
Is this your own code or you running an existing RFA SDK example? Nope
If an existing RFA example, have you changed the example, if so
changes? There is no change in the code in recent times
we are using the following RFA version of the library 8.1.0.L1
The message indicates that OMMMSg you are trying to publish is incomplete i.e. missing the AttribInfo
However, you will need to provide some more detail so that we can help you - there is not sufficient information provided.
If an existing RFA example, have you changed the example, if so what changes?
If you can provide the code snippet for the OMMMsg encoding and submit that would be good. Please attach the code in a text file rather than posting directly into the reply.
Thanks for attaching some source code. Unfortunately, the source is primarily subscriber related and does not show any of the relevant provider code - in particular how you encode RespMsg before submitting it to the API for publishing.
One thing to note is that for Refresh type RespMsg it must include AttribInfo, whereas it is can be optional for an Update type Resp - depending on the ReqMsg specification.
