RFA Data Dictionary error
Just install my application on the new server and found the following error, do you know what does the error mean?
[Wed Jun 07 14:22:56 2017]: (ComponentName) SSLED_Adapter: (Severity) Information: SSLED data dictionary information: downloadDataDict = false, masterFidFile = D:\MDServer\appendix_a, enumTypeFile = D:\MD Server\enumtype.def, supportFullDataDictFromFile = true. (null)
[Wed Jun 07 14:22:56 2017]: (ComponentName) SSLED_Adapter: (Severity) Warning: MarketDataDictSub open request failed, error: Data Dictionary does not exist or Data Dictionary is empty or Server does not support to download Data Dictionary
treprfarfa-apierrorssl
7.6k 15 6 9
@Akechi Sato
The warning message means RFA unable to load data dictionary from masterFidFile and enumTypeFile you specified in RFA configuration.
I guess that you have the following config in RFA configuration file. \Adapters\SSLED_Adapter\masterFidFile= "D:\MDServer\appendix_a" \Adapters\SSLED_Adapter\enumTypeFile= "D:\MDServer\enumtype.def"
\Adapters\SSLED_Adapter\downloadDataDict= false
Please check if you have both file in the “D:\MDServer” and your application have permission to access the file.
