I am trying to run a TRTH intraday pull using the following parameters (code depends on json and requests modules):
data_json = json.dumps({
"ExtractionRequest": {
"@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryIntradaySummariesExtractionRequest",
"ContentFieldNames": ['Close Bid', 'No. Trades'],
"IdentifierList": {
"InstrumentIdentifiers": [
{"Identifier": 'SCNY', "IdentifierType": "Ric"}
"ValidationOptions" : {"AllowOpenAccessInstruments": True, "AllowHistoricalInstruments": True},
"UseUserPreferencesForValidationOptions" : False
"Condition": {
"ReportDateRangeType": "Range",
"QueryStartDate": "2017-01-01",
"QueryEndDate": "2017-01-31",
"SummaryInterval": "OneHour",
"MessageTimeStampIn": "GmtUtc"
The header I use at this stage is
header_dict = {'Prefer': 'respond-async, wait=5', 'Content-Type': 'application/json; odata=minimalmetadata',
'Accept-Charset': 'UTF-8', 'Authorization': 'Token ' + token}
I am able to submit this for a valid JobId, but when I go to retrieve the results, they end up containing no data:
Empty DataFrame
Columns: [#RIC, Domain, Date-Time, GMT Offset, Type, No. Trades, Close Bid]
Index: []
My header when trying to retrieve results is
pull_header_dict = {'Prefer': 'respond-async', 'Content-Type': 'Accept-Encoding: gzip, deflate',
Could someone explain why the data is coming back empty? I receive Status 200 from every request along the way, including the last one, and this pull has been run previously by another user (so there should be data). Despite being empty data-wise, the final output does include accurate column names, so I believe the request is being interpreted correctly. Thank you in advance.
