I am using Java EMA API and using batch to fetch data from Elektron. I get the following error, when RICs are sent using batch array,
Exception in thread "main" Exception Type='OmmInvalidUsageException', Text='Failed to rsslElementEntry.encode() while encoding rssl elementlist. Reason='INVALID_DATA'', Error Code='-29'
at com.thomsonreuters.ema.access.CollectionDataImpl.ommIUExcept(CollectionDataImpl.java:64)
at com.thomsonreuters.ema.access.ElementListImpl.encodedData(ElementListImpl.java:391)
at com.thomsonreuters.ema.access.MsgImpl.msgPayload(MsgImpl.java:835)
at com.thomsonreuters.ema.access.ReqMsgImpl.payload(ReqMsgImpl.java:649)
at EMAConsumer.Consumer.main(Consumer.java:520)
This error appears on execution of the following line,
consumer.registerClient(EmaFactory.createReqMsg().serviceName("ELEKTRON_DD").payload(batchView), appClient);
When I divided the RICs into multiple files, to check for the RIC which is creating this error. This error stopped coming. I am attaching here txt file of RIC codes which throws this error. Can anybody help me resolve this error? and what is the cause?
Dhruv
