Hi, on Sunday night Japan local time my client experienced errors connecting to our real-time using below execution code to see those error logs.
It became working on Monday morning without doing any trouble-shooting so wondered if there any maintenance work on weekend.
As I checked on MyAccount it seemed there was no maintenance announcement made in the given time range (Sunday night, GMT+9) but wanted to clarify if anybody don't see any issue on the code before I get back to the client to see other possible issue on their system.
Thanks a lot for the checking in advance.
=== Code ===
CsvCreatorAppClient csvCreatorAppClient = new CsvCreatorAppClient(consumer, marketTerm, csvWriter); OmmConsumerConfig config = EmaFactory.createOmmConsumerConfig(); consumer = EmaFactory.createOmmConsumer(config.host( "localhost:14002").username("tradeSci"));
=== Error Messages ===
info: loggerMsg ClientName: EmaConfig Severity: Info Text: reading configuration file [EmaConfig.xml] from [D:\dev\ReutersApiDataGet\Elektron\EmaSample] loggerMsgEnd [Sun 2 05 17:59:13 JST 2017] Important: loggerMsg ClientName: EmaConfig Severity: Error Text: Cannot locate configuration source EmaConfig.xml loggerMsgEnd [Sun 2 05 17:59:13 JST 2017] Warning: loggerMsg ClientName: ChannelCallbackClient Severity: Warning Text: Received ChannelDownReconnecting event on channel Channel RsslReactor Channel is null Error Id 0 Internal sysError 0 Error Location Reactor.processWorkerEvent Error text Error - exceeded initialization timeout (5 s) loggerMsgEnd [Sun 2 05 17:59:18 JST 2017] Warning: loggerMsg ClientName: ChannelCallbackClient Severity: Warning Text: Received ChannelDownReconnecting event on channel Channel RsslReactor Channel is null Error Id 0 Internal sysError 0 Error Location Reactor.processWorkerEvent Error text Error - exceeded initialization timeout (5 s) loggerMsgEnd [Sun 2 05 17:59:24 JST 2017] Warning: loggerMsg ClientName: ChannelCallbackClient Severity: Warning Text: Received ChannelDownReconnecting event on channel Channel RsslReactor Channel is null Error Id 0 Internal sysError 0 Error Location Reactor.processWorkerEvent Error text Error - exceeded initialization timeout (5 s) loggerMsgEnd [Sun 2 05 17:59:31 JST 2017]
