message tracking
message tracking
To turn on XML Trace file in EMA Consumer, you need to add parameter XmlTraceToFile value=“1” to EmaConfig.xml as below sample. Default file name is EmaTrace_ You can find all parameters support by Consumer from Ema Configuration Guide section unser section 3.1.4 Consumer Entry Parameters
<ConsumerList> <Consumer> <Name value="Consumer_1"/> <Channel value="Channel_1"/> <Logger value="Logger_1"/> <Dictionary value="Dictionary_1"/> <XmlTraceToFile value="1"/> </Consumer> </ConsumerList>
