OmmInvalidUsageException login failed (timed out)
Hi
I get the following error when trying to execute the jar file from ec2
20:08:56.666 [main] ERROR com.thomsonreuters.ema.access.OmmConsumerImpl - loggerMsg
Severity: Error
Text: Received ChannelDown event on channel Channel_1
Instance Name Consumer_1_1
RsslReactor Channel is null
Error Id 0
Internal sysError 0
Error Location Reactor.processWorkerEvent
Error text Error initializing channel: errorId=0 text=null
loggerMsgEnd
Exception in thread "main" Exception Type='OmmInvalidUsageException', Text='login failed (timed out after waiting 45000 milliseconds) for amer-3.pricing.streaming.edp.thomsonreuters.com:14002)', Error Code='-4052'
at com.thomsonreuters.ema.access.OmmBaseImpl.ommIUExcept(OmmBaseImpl.java:1380)
at com.thomsonreuters.ema.access.OmmBaseImpl.handleLoginReqTimeout(OmmBaseImpl.java:1193)
at com.thomsonreuters.ema.access.OmmConsumerImpl.handleAdminDomains(OmmConsumerImpl.java:446)
at com.thomsonreuters.ema.access.OmmBaseImpl.initialize(OmmBaseImpl.java:280)
at com.thomsonreuters.ema.access.OmmConsumerImpl.<init>(OmmConsumerImpl.java:43)
at com.thomsonreuters.ema.access.EmaFactory.createOmmConsumer(EmaFactory.java:236)
at EMAConsumer.Consumer.main(Consumer.java:261)
But when i run the jar file on my local system, it runs fine and keeps pulling the data. I have enabled port 14002 also on ec2. Please let me know, if i need to do anything else?
Dhruv
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apierror
23k 22 9 14
In conclusion, quoting from comments:
"It is solved now. I was using \\home\\ubuntu\\keystore.jks instead of //home//ubuntu//keystore.jks. It should have been // instead of \\ in my configuration file. "
The OmmConsumer throws an invalid usage exception when it times out in the constructor waiting for the login or connection up event. This is a built in behavior. Does your app handle exceptions?
Please post the code of your app to see if everything is "as designed".
