Start App Studio Debugger- Error
I am getting a below while trying to run the Eikon app using “Start App Studio Debugger” button along with “Eikon Host”. Its neither through any error nor catching any breakpoints, other than Thread exit code. Kindly look into it and let me know if its required any permission or anything I’m missing here. Error:- 'EikonBox.exe' (CLR v4.0.30319: OpenEikonDevs_20338133_1Domain): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_32\System.Web\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled. 'EikonBox.exe' (CLR v4.0.30319: OpenEikonDevs_20338133_1Domain): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Net.Http\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Net.Http.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled. The thread 0x184c has exited with code 259 (0x103). The thread 0x2230 has exited with code 259 (0x103). The program '[11232] EikonBox.exe' has exited with code 0 (0x0).
eikoneikon-app-studio
Do you mean "App Studio Developer" menu in Visual Studio?
If yes, you may need to verify the problem from EikonDevAddIn.log. It is in
%localappdata%\temp\EikonDevAddInLogs directory.
