JET Quote subscribe to all available fields
Does anyone know if it's possible to make a Quote subscription via JET api (without having to provide a Field) for all available fields? This is the code to subscribe: var quote = JET.Quotes.create() .rics("GOOG.O") .onUpdate(function (subscription, ric, updatedValues) { var allFieldsValues = subscription.getFieldsValues(ric); }) .start(); This is the ERROR: Uncaught Chain or a RICs and at least one field should be specified to start a subscription Quote.js: 435 Does JET Quote plugin always require the field list (at least one field)? I understand you can specify the fields in the request (but I want to get back the full list of fields) .rawFields("CF_BID") or .formattedFields("PCTCHNG") Thanks
eikoneikon-app-studiojet
I found the answer:
You can use “*” as a parameter in rawFields() or formattedFields() in Quotes plug-in object.
.rics("GOOG.O")
.rawFields("*")
console.log(subscription.getFieldsValues(ric)); })
.start();
Just a thought: do you really need all fields ? The more fields you subscribe to, the heavier the load on the app and machine running it.
