Error initializing channel 1 (example code)
Hi
I am following the example from the below link
https://developers.refinitiv.com/article/expanding-ema-java-consumer-example-provide-web-services-rest
and is receiving this error. I don't know, why there is connection refusal, though I am using 14002 port.
I am using canned data RDMFieldDictionary and EMAConfig.xml and under Consumer1, changed the Dictionary1 to Dictionary2 (as told in the example link mentioned above) and Dictionary2 refers to the files (files in bold)
Please help me in resolving the error. Thanks
Jul 09, 2020 6:46:41 PM com.thomsonreuters.ema.access.ChannelCallbackClient reactorChannelEventCallback
SEVERE: loggerMsg
Severity: Error
Text: Received ChannelDown event on channel Channel_1
Instance Name Consumer_1_1
RsslReactor @660acfb
RsslChannel @238d68ff
Error Id 0
Internal sysError 0
Error Location Reactor.processWorkerEvent
Error text Error initializing channel: errorId=-1 text=Connection refused: no further information
loggerMsgEnd
login failed (timed out after waiting 45000 milliseconds) for localhost:14002)
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apierror
@dhruv.arora
The error indicates that the consumer application was unable to connect to localhost:14002.
How did you run the canned data?
To replay the canned data, please refer to the Quick Start Guide to Recording and Playback of Elektron Data article.
7.6k 15 6 9
@dhruv.arora
Are you running sink_driven_src with the canned data on the same machine you are running the EMA example?
Can you test one of the EMA consumer examples with the sink_driven_src and get the same result?
Hi @moragodkrit I am running example102__MarketPrice__Snapshot. Yes, I am using the canned data.
I forgot to mention, I am running the example on the same machine, where I have canned data and as mentioned on the article (link given in my question), I setup the Tomcat server.
