Searching an organisation by country using Zero footprint screening API
I want to search an organization by country. The JSON which I currently use is the below one. When I use the below JSON, I am getting the below error.
"groupId": "0a360b84-6d9a-189f-9b80-b0c000005df2",
"entityType": "organisation",
"providerTypes": [
"WATCHLIST"
"name": "VIDEO S A .-",
"secondaryFields": [
"typeId": "SFCT_6",
"value": "ARG"
Error:
"error": "INVALID_ENTITY_TYPE",
"cause": "Entity type is mandatory and must be one of: INDIVIDUAL, ORGANISATION, VESSEL, UNSPECIFIED and must be compatible with each provider type used in screening a case."
Please let me know the correct JSON format to search an organization by country.
world-checkworld-check-oneworld-check-one-zf
4.5k 4 7 8
@Kathirvel.Dhanavelu,
The WC1 ZFS API in pilot has synthetic data so not all the results will be returned. Here are a few sample names which you may use to test out the results. Please refer to the following link - https://developers.refinitiv.com/customer-and-third-party-screening/world-check-one-zero-footprint-screening-api/quick-start?content=68424&type=quick_start
Section -Zero Footprint Synthetic Names Examples
Hope this helps.
4.5k 4 7 8
Please use the "entityType": "ORGANISATION" instead of "entityType": "organisation" as it is case sensitive.
Hope this clarifies your concern.
We have used the below JSON now.
"groupId": "0a3687d0-6c28-1345-9b12-599f000008d2",
"entityType": "ORGANISATION",
"providerTypes": [
"WATCHLIST"
"typeId": "SFCT_6",
"value": "ARG"
We are getting the below response from Zero footprint screening API
"results": [],
"nameTransposition": false
Please check and let us know whether this is the valid output or whether we need change any attribute in the input JSON ?.
