Hello, My application need to do sanction screening which will give a name in the API request and the response indicates either HIT or NON-HIT. For this requirement which API call I have to make. Many Thanks in advance!
world-checkworld-check-oneworld-check-one-zf
4.2k 7 5 6
@nisar.c
To screen a case, you can use the API call "
SEQ-zfs-api-sync-screen-simple: Perform Zero Footprint Synchronous Screening: Simple" .
This API call lets you send an entity name to be screened and returns a response consisting of matches with match strength "EXACT", "STRONG", "MEDIUM" and "WEAK".
Kindly note you would need to supply a correct group Id to make this work. You can use the API call "SEQ-pre-groups: Get my top-level groups" to find out your group Ids.
If you would like to include secondary fields (such as DOB, nationality, etc) in the payload/body of your screening request, then please call the API "SEQ-pre-group-case-template: Get the case template for a group" to know the UUIDs that you can use to add the desired secondary fields to the payload and to screen it against them.
Thank you for your answer.
@nisar.c I am glad that your query was answered. Request you to accept the answer so that it helps other users in the developer community.
