401 response on cases/screeningRequest with python
import requests
import hmac
import hashlib
import base64
import time
import json
# To get the GMT time
stringdataformat = ("%a, %d %b %Y %H:%M:%S GMT")
datenow = time.gmtime()
date = time.strftime(dataformat, datenow)
print(date) api_key = "xxxxxxxxxxxxxxxxxxxx"
# Enter your API key
api_secret = "xxxxxxxxxxxxxxxxxxxxxxx"
# Enter your API secret
group_id = "xxxxxxxxxxxxxxxxxxxxxxx"
# Enter your group Id
api_token = api_secret.encode()
path = "https://rms-world-check-one-api-pilot.thomsonreuters.com/v2/cases/screeningRequest"
gatewayurl = "/v2/"
gatewayhost = "rms-world-check-one-api-pilot.thomsonreuters.com"
content_type = "application/json"
name1 = "putin"
entity_type = "INDIVIDUAL"
bcontent = "{\n\"secondaryFields\": [],\n  \"entityType\": \"" + entity_type + "\",\n  \"customFields\": [],\n  \"groupId\":\"" + group_id + "\",\n  \"providerTypes\": [\n    \"WATCHLIST\"\n  ],\n  \"name\": \"" + name1 + "\"}"
content = bcontent.encode('utf-8')length = len(content)
str_length = str(length)
datatosign = "(request-target): post " + gatewayurl + "cases/screeningRequest\n" + \             "host: " + gatewayhost + "\n" + \             "date: " + date + "\n" + \             "content-type: " + content_type + "\n" + \             "content-length: " + str_length + "\n" + \             content.decode()
byte_datatosign = datatosign.encode()
def hbase(byte_datatosign, api_token):
encrypt = hmac.new(api_token, byte_datatosign, digestmod=hashlib.sha256)
digest_maker = encrypt.digest()
base = base64.b64encode(digest_maker)
return base.decode()
hmacbase = hbase(byte_datatosign, api_token)
print(hmacbase)
authorisation = "Signature keyId=\"" + api_key + "\"" + ",algorithm=\"hmac-sha256\"" + ",headers=\"(request-target) host date content-type content-length\"" + ",signature=\"" + hmacbase + "\""
print(authorisation)
headers = {     'Authorization': authorisation,    'Date': date,    'Content-Type': content_type,    'Content-Length': str_length,    'Accept': "*/*",    'Cache-Control': "no-cache",    'Host': "rms-world-check-one-api-pilot.thomsonreuters.com",    'Accept-Encoding': "gzip, deflate",    'Connection': "keep-alive",    'cache-control': "no-cache"}
requests.post(path, data=content, headers=headers)
I'm trying to make a screening request with the following code with python and it keeps returning 401 errors. What am I doing wrong?
pythonworld-checkworld-check-one
Hello @kingsley,
Thank you for your participation in the forum.
Is the reply below satisfactory in resolving your query? If yes please click the 'Accept' text next to the reply. This will guide all community members who have a similar question. Otherwise please post again offering further insight into your question.
Thanks,
-AHS
4.5k 4 7 8
@kingsley,
Thank you for your query.
Could you please refer to the python example share in the below link?
https://community.developers.refinitiv.com/questions/47570/please-can-you-post-a-sample-python-file-that-can.html
Please let us know if you need further assistance.
