I have been trying to create a sample API integration project using Python. I have tried to follow the steps as in Postman and as in the Java Sample World Check Application from the Downloads section.
When I run the code, I keep getting the 401 Unauthenticated Error. I believe it is due to the incorrect generation of the hmac. When trying with the same date variable in Postman and Python, the signatures don't match.
Could you please provide a sample code which would help me generate the proper signature so that I can get a groupId as the response? (The response is 200 when doing the same from POSTMAN)
P.S. I have tried using one of the sample code for provided for Python from one of the solutions posted here. That does not seem to work. I tried different methods for generating a similar hmac as CryptoJS does, but it did not work out for me.
Thanks,
Aman
