Getting 401 Unauthorized World Check API
import requests
import hmac
import hashlib
import base64
import time
import json
import io
null = None
false = None
# To get the GMT time string
dataformat = ("%a, %d %b %Y %H:%M:%S GMT")
datenow = time.gmtime()
date = time.strftime(dataformat, datenow)
print(date)
api_key = "xxxxxxxxxxxxxxxxxxxx"  # Enter your API key
api_secret = "xxxxxxxxxxxxxxxxxxxxxxx"  # Enter your API secret
group_id = "xxxxxxxxxxxxxxxxxxxxxxx"  # Enter your group Id
api_token = api_secret.encode()
path = "https://rms-world-check-one-api-pilot.thomsonreuters.com/v2/cases"
gatewayurl = "/v2/"
gatewayhost = "rms-world-check-one-api-pilot.thomsonreuters.com"
content_type = "application/json"
name1 = "putin"
entity_type = "INDIVIDUAL"
bcontent = "{\n\"secondaryFields\": [],\n  \"entityType\": \"" + entity_type + "\",\n  \"customFields\": [],\n  \"groupId\":\"" + group_id + "\",\n  \"providerTypes\": [\n    \"WATCHLIST\"\n  ],\n  \"name\": \"" + name1 + "\"}"
content = bcontent.encode('utf-8')
length = len(content)
str_length = str(length)
datatosign = "(request-target): post " + gatewayurl + "cases/screeningRequest\n" + \
             "host: " + gatewayhost + "\n" + \
             "date: " + date + "\n" + \
             "content-type: " + content_type + "\n" + \
             "content-length: " + str_length + "\n" + \
             content.decode()
print(datatosign)
byte_datatosign = datatosign.encode()
def hbase(byte_datatosign, api_token):
    encrypt = hmac.new(api_token, byte_datatosign, digestmod=hashlib.sha256)
    digest_maker = encrypt.digest()
    base = base64.b64encode(digest_maker)
    return base.decode()
hmacbase = hbase(byte_datatosign, api_token)
print(hmacbase)
authorisation = "Signature keyId=\"" + api_key + "\"" + ",algorithm=\"hmac-sha256\"" + ",headers=\"(request-target) host date content-type content-length\"" + ",signature=\"" + hmacbase + "\""
print(authorisation)
headers = {
    'Authorization': authorisation,
    'Date': date,
    'Content-Type': content_type,
    'Content-Length': str_length,
    'Accept': "*/*",
    'Cache-Control': "no-cache",
    'Host': "rms-world-check-one-api-pilot.thomsonreuters.com",
    'Accept-Encoding': "gzip, deflate",
    'Connection': "keep-alive",
    'cache-control': "no-cache"
print(headers)
try:
    result = requests.request("POST", path, headers=headers, data=content)
    result.raise_for_status()
    print(result.status_code)
    print(result.headers)
    result_json = result.json()
    with io.open("result_json.txt", 'w', encoding="utf-8") as outfile:
        outfile.write(str(json.dumps(result_json, ensure_ascii=False, indent=4)))
    print(result_json)
except requests.exceptions.HTTPError as errh:
    print("Http Error:", errh)
except requests.exceptions.ConnectionError as errc:
    print("Error Connecting:", errc)
except requests.exceptions.Timeout as errt:
    print("Timeout Error:", errt)
except requests.exceptions.RequestException as err:
    print("OOps: Something Else", err)
pythonworld-checkworld-check-one
2.4k 5 5 5
@sagarmanohara.rao-ext
I would like to highlight an observation that I made on the path that you have declared in the code i.e "https://rms-world-check-one-api-pilot.thomsonreuters.com/v2/cases" which is for the endpoint to save a case API(async screening) and I also see that in dataToSign section of the code the endpoint declared is of sync screening i.e. "cases/screeningRequest".
There is an obvious discrepancy here and I believe this might be the potential cause for the 401 that you're observing. Please clarify the endpoint that you would like to use i.e. save a case or sync screen a case and make the corrections accordingly under the path and dataToSign section of your code.
Let me know if this solves the issue.
Regards,
Mehran Khan
APIs are working fine in postman but not in python they are returning 401
I want to save the case.
2.4k 5 5 5
Please edit the endpoint detail in your dataToSign section to just "cases" from "cases/screeningRequest".
Let me know if this works.
