Problem when retrieving profiles - Read timed out
Hi guys,
We are seeing errors while retrieving profiles for some cases. They are intermittent and not related to number of profiles per case (we had examples with 250 and 2 profiles failing the same way).
Example details from few minutes ago:
Requested URL: https://rms-world-check-one-api.thomsonreuters.com/v1/cases/5l8v5ywc7xm91enemz0jyd33v/screeningRequest
Error message: Read timed out
We also so a number of errors where the error message was: Remote host closed connection during handshake.
Occurence chart attached:
Let me know what additional information do you need.
Thanks,
world-checkworld-check-oneerror
2.4k 5 5 5
@leszek.sosnowski
Can you please provide us the complete requests and responses including the timestamps of a few of the timeout occurrences?
Also, are you facing this issue only with the above endpoint?
Regards
Two examples representing two different endpoints below. Timestamp in the request header.
Example 1
Error message: Remote host closed connection during handshake, cause: java.io.EOFException: SSL peer shut down incorrectly.
Requested URL: https://rms-world-check-one-api.thomsonreuters.com/v1/cases/5l8v5uy9x3b01enffma1hrhdx/screeningRequest
Request Headers: Date : Fri, 15 May 2020 12:40:17 GMT, Content-Type : application/json, Authorization : Signature keyId="xxx",algorithm="hmac-sha256",headers="(request-target) host date",signature="OTrWuoXFGf1DHMwT5tciw3HGkffrMZ1I3LYUEcHP8Mw="] with root cause
Example 2
Requested URL: https://rms-world-check-one-api.thomsonreuters.com/v1/cases/5l8v64tfk39p1enfsc36nag0g/results
Request Headers: Date : Thu, 14 May 2020 19:25:20 GMT, Content-Type : application/json, Authorization : Signature keyId="xxx",algorithm="hmac-sha256",headers="(request-target) host date",signature="Oy6jrDdsyPZ2oBB98X1t5tubSLXFsw5xxeI88u8XAQ8="] with root cause
Thanks,
2.4k 5 5 5
@leszek.sosnowski
Thank you for the details, let me investigate this further and get back with my analysis.
Regards
2.4k 5 5 5
@leszek.sosnowski
A quick update, I have forwarded the data to our support team and they will be reaching out to you shortly and helping you with this.
I appreciate the patience.
Thank you,
Mehran Khan
