Dear Osama Sammour,
When screening "khaled el sabeh" I also get a strong match on the result you have described. The match was done on the native alias. This can be a phonetic or other factor impacting the match.
"referenceId": "e_tr_wci_2927101", "matchStrength": "STRONG", "matchedTerm": "خالد مجاور", "submittedTerm": "khaled el sabeh", "matchedNameType": "NATIVE_AKA",
If you do not want Native Aliases to surface and be used int he matching process you can remove them from the group:
Best Regards,
Léo
